Ogre 2.x implementation of the spot light class. More...
#include <Ogre2Light.hh>
virtual ~Ogre2SpotLight ()
virtual double Falloff () const override
virtual math::Angle InnerAngle () const override
virtual math::Angle OuterAngle () const override
virtual void SetFalloff (double _falloff) override
virtual void SetInnerAngle (const math::Angle &_angle) override
virtual void SetOuterAngle (const math::Angle &_angle) override
- Public Member Functions inherited from BaseSpotLight< Ogre2Light >
virtual ~BaseSpotLight ()
virtual ~SpotLight ()
virtual ~Light ()
virtual ~Ogre2Light ()
 Destroy the light. More...
virtual ~BaseLight ()
virtual ~Ogre2Node ()
 Ogre2SpotLight ()
- Protected Member Functions inherited from BaseSpotLight< Ogre2Light >
 BaseSpotLight ()
 Ogre2Light ()
 Initialize the light. More...
 BaseLight ()
 Ogre2Node ()
 Set the parent node. More...
double attenConstant = 1.0
double attenLinear = 0.0
double attenQuadratic = 0.0
double attenRange = 100.0
 Attenuation range. More...
 Light type. More...
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2SpotLight()
Ogre2SpotLight ( )
◆ ~Ogre2SpotLight()
virtual ~Ogre2SpotLight ( )
◆ Direction()
The direction of the light
Implements SpotLight.
◆ Falloff()
The falloff of the spotlight
◆ InnerAngle()
◆ OuterAngle()
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseSpotLight< Ogre2Light >.
◆ SetFalloff()
◆ SetInnerAngle()
◆ SetOuterAngle()
