OgreRenderPass Class Reference
Ogre implementation of the RenderPass class. More...
#include <OgreRenderPass.hh>
virtual | ~OgreRenderPass () |
Destructor. More... | |
virtual void | CreateRenderPass () |
Create the render pass using ogre compositor. More... | |
void | Destroy () override |
virtual void | SetCamera (Ogre::Camera *_camera) |
Set the ogre camera that the render pass applies to. More... | |
virtual | ~BaseRenderPass () |
virtual bool | IsEnabled () const override |
Get whether or not the render pass is enabled. More... | |
virtual void | SetEnabled (bool _enabled) override |
Set to enable or disable the render pass. More... | |
virtual | ~RenderPass () |
virtual bool | IsEnabled () const =0 |
virtual | ~Object () |
virtual | ~OgreObject () |
virtual ScenePtr | Scene () const |
virtual | ~BaseObject () |
virtual unsigned int | Id () const override |
virtual std::string | Name () const override |
virtual void | PostRender () override |
virtual void | PreRender () override |
OgreRenderPass () | |
Constructor. More... | |
BaseRenderPass () | |
OgreObject () | |
BaseObject () | |
virtual void | Init () |
virtual void | Load () |
Protected Attributes | |
Ogre::Camera * | ogreCamera = nullptr |
Pointer to the ogre camera. More... | |
bool | enabled |
Flag to indicate if render pass is enabled or not. More... | |
OgreScenePtr | scene |
unsigned int | id |
std::string | name |
◆ OgreRenderPass()
protected |
◆ ~OgreRenderPass()
virtual |
◆ CreateRenderPass()
virtual |
Reimplemented in OgreGaussianNoisePass.
◆ Destroy()
overridevirtual |
◆ SetCamera()
virtual |
[in] _camera Pointer to the ogre camera.
◆ ogreCamera
protected |
