OgreGaussianNoisePass Class Reference
Ogre implementation of the GaussianNoisePass class. More...
#include <OgreGaussianNoisePass.hh>
 OgreGaussianNoisePass ()
virtual ~OgreGaussianNoisePass ()
void Destroy () override
void PreRender () override
- Public Member Functions inherited from BaseGaussianNoisePass< OgreRenderPass >
virtual ~BaseGaussianNoisePass ()
double Bias () const
 Accessor for bias. More...
double Mean () const
 Accessor for mean. More...
void SetBiasMean (double _biasMean)
 Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
void SetBiasStdDev (double _biasStdDev)
 Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
void SetMean (double _mean)
 Set mean. More...
void SetStdDev (double _stdDev)
 Set stddev. More...
double StdDev () const
 Accessor for stddev. More...
- Public Member Functions inherited from GaussianNoisePass
virtual ~GaussianNoisePass ()
virtual double Bias () const =0
virtual double Mean () const =0
virtual double StdDev () const =0
virtual ~RenderPass ()
- Public Member Functions inherited from OgreRenderPass
virtual ~OgreRenderPass ()
 Set the ogre camera that the render pass applies to. More...
virtual ~BaseRenderPass ()
Public Attributes
std::shared_ptr< GaussianNoiseCompositorListener > gaussianNoiseCompositorListener
 Gaussian noise compositor listener. More...
Ogre::CompositorInstance * gaussianNoiseInstance = nullptr
 Gaussian noise compositor. More...
- Protected Member Functions inherited from BaseGaussianNoisePass< OgreRenderPass >
void SampleBias ()
- Protected Member Functions inherited from OgreRenderPass
 OgreRenderPass ()
 BaseRenderPass ()
virtual void Init ()
- Protected Attributes inherited from BaseGaussianNoisePass< OgreRenderPass >
double bias
 Gaussian noise bias. More...
double biasMean
 The mean of the Gaussian distribution from which bias values are drawn. More...
double biasStdDev
 The standard deviation of the Gaussian distribution from which bias values are drawn. More...
double mean
 Gaussian noise mean. More...
double stdDev
 Standard deviation of Gaussian noise. More...
- Protected Attributes inherited from OgreRenderPass
bool enabled
◆ OgreGaussianNoisePass()
◆ ~OgreGaussianNoisePass()
virtual ~OgreGaussianNoisePass ( )
◆ CreateRenderPass()
void CreateRenderPass ( )
void Destroy ( )
void PreRender ( )
◆ gaussianNoiseCompositorListener
std::shared_ptr<GaussianNoiseCompositorListener> gaussianNoiseCompositorListener
◆ gaussianNoiseInstance
Ogre::CompositorInstance* gaussianNoiseInstance = nullptr
