gz/rendering/ogre2/Ogre2Camera.hh
Definition: gz/rendering/base/BaseCamera.hh:47
Ogre2.x implementation of the camera class.
Definition: gz/rendering/ogre2/Ogre2Camera.hh:45
virtual unsigned int AntiAliasing() const override
Ogre2SelectionBuffer * SelectionBuffer() const
Get the selection buffer object.
Ogre2RenderTargetPtr renderTexture
Pointer to render texture.
Definition: gz/rendering/ogre2/Ogre2Camera.hh:169
virtual void SetVisibilityMask(uint32_t _mask) override
Set visibility mask.
void DestroyRenderTexture()
Destroy render texture created by CreateRenderTexture() Note: It's not virtual.
virtual void SetBackgroundColor(const math::Color &_color)
virtual RenderTargetPtr RenderTarget() const override
Ogre::Camera * OgreCamera() const
virtual RenderWindowPtr CreateRenderWindow() override
Create a render window.
virtual math::Angle HFOV() const override
virtual double AspectRatio() const override
virtual void SetFarClipPlane(const double _far) override
virtual void SetBackgroundMaterial(MaterialPtr _material)
Set the background material of this camera.
virtual void SetSelectionBuffer()
Create and set selection buffer object TODO(anyone) to be implemented.
virtual math::Color BackgroundColor() const
virtual math::Matrix4d ViewMatrix() const override
virtual unsigned int RenderTextureGLId() const override
Get the OpenGL texture id associated with the render texture used by this camera. A valid id is retur...
math::Color backgroundColor
Color of background.
Definition: gz/rendering/ogre2/Ogre2Camera.hh:172
virtual void SetMaterial(const MaterialPtr &_material) override
virtual void SetAspectRatio(const double _ratio) override
Set the camera's aspect ratio. This value determines the cameras vertical field-of-view....
virtual void SetProjectionType(CameraProjectionType _type) override
Set the projection type for this camera This changes the projection matrix of the camera based on the...
virtual MaterialPtr BackgroundMaterial() const
Get the background material of this camera.
virtual VisualPtr VisualAt(const ignition::math::Vector2i &_mousePos) override
virtual void SetHFOV(const math::Angle &_hfov) override
virtual void SetProjectionMatrix(const math::Matrix4d &_matrix) override
Set the projection matrix for this camera. This overrides the standard projection matrix computed bas...
virtual void Init() override
virtual void SetAntiAliasing(const unsigned int _aa) override
Set the level of anti-aliasing used during rendering. If a value of 0 is given, no anti-aliasing will...
virtual void SetNearClipPlane(const double _near) override
virtual void Render() override
Renders the current scene using this camera. This function assumes PreRender() has already been calle...
virtual void CreateRenderTexture()
Create a render texture for the camera for offscreen rendering.
void SetShadowsDirty() override
virtual math::Matrix4d ProjectionMatrix() const override
A Ray Query class used for computing ray object intersections.
Definition: gz/rendering/ogre2/Ogre2RayQuery.hh:40
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
Generates a selection buffer object for a given camera. The selection buffer is used of entity select...
Definition: gz/rendering/ogre2/Ogre2SelectionBuffer.hh:48
Enum for projection types.
Definition: gz/rendering/Camera.hh:41
