Factory.hh File Reference
#include <algorithm>
#include <cstdint>
#include <cstring>
#include <deque>
#include <map>
#include <memory>
#include <string>
#include <utility>
#include <vector>
#include <gz/common/SingletonT.hh>
#include <gz/common/Util.hh>
#include <gz/sim/config.hh>
#include <gz/sim/Export.hh>
#include <gz/sim/Types.hh>
#include <gz/utils/NeverDestroyed.hh>
class  ComponentDescriptor< ComponentTypeT >
 A class for an object responsible for creating components. More...
class  ComponentDescriptorBase
 A base class for an object responsible for creating components. More...
class  ComponentDescriptorQueue
 A class to hold the queue of component descriptors registered by translation units. This queue is necessary to ensure that component creation continues to work after plugins are unloaded. The typical scenario this aims to solve is: More...
class  Factory
 A factory that generates a component based on a string type. More...
struct  RegistrationObjectId
 A wrapper around uintptr_t to prevent implicit conversions. More...
namespace  gz
namespace  gz::sim
Macros
#define GZ_SIM_REGISTER_COMPONENT(_compType, _classname)
Macro Definition Documentation
◆ GZ_SIM_REGISTER_COMPONENT
#define GZ_SIM_REGISTER_COMPONENT (   _compType,
  _classname
Value:
class GzSimComponents##_classname \
public: GzSimComponents##_classname() \
using namespace gz;\
sim::components::Factory::Instance()->Register<_classname>(\
_compType, new Desc(), sim::components::RegistrationObjectId(this));\
public: GzSimComponents##_classname( \
const GzSimComponents##_classname&) = delete; \
public: ~GzSimComponents##_classname() \
using namespace gz; \
sim::components::Factory::Instance()->Unregister<_classname>( \
sim::components::RegistrationObjectId(this)); \
static GzSimComponents##_classname\
GzSimComponentsInitializer##_classname;
Use this macro to register components.
Each time a plugin which uses a component is loaded, it tries to register the component again, so we prevent that.
[in]_compTypeComponent type name.
[in]_classnameClass name for component.
