UserCommands Class Referencefinal
This system provides a Gazebo Transport interface to execute commands while simulation is running. More...
#include <UserCommands.hh>
 UserCommands ()
 ~UserCommands () final
 Configure the system. More...
 All received commands are queued in order of reception and executed in order during PreUpdate. More...
Todo:
(louise) In the future, an interface undo/redo commands will also be provided.
Spawn entity
Spawn multiple entities
This service can spawn multiple entities in the same iteration, thereby eliminating simulation steps between entity spawn times.
Set entity pose
This service set the pose of entities
Set multiple entity poses
This service set the pose of multiple entities
Try some examples described on examples/worlds/empty.sdf
◆ UserCommands()
UserCommands ( )
◆ ~UserCommands()
~UserCommands ( )
final
finalvirtual
[in]_infoContains information about the current simulation iteration.
[in]_ecmThe entity component manager.
