| virtual | ~BaseThermalCamera () |
| | Destructor.
| virtual float | AmbientTemperature () const override |
| | Get the ambient temperature of the environment.
| virtual float | AmbientTemperatureRange () const override |
| | Get the range of ambient temperature.
| virtual gz::common::ConnectionPtr | ConnectNewThermalFrame (std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override |
| | Connect to the new thermal image event.
| virtual float | HeatSourceTemperatureRange () const override |
| | Get the range of temperature variation for all heat sources.
| virtual float | LinearResolution () const override |
| | Get the temperature linear resolution.
| virtual float | MaxTemperature () const override |
| | Get the maximum temperature the sensor can detect.
| virtual float | MinTemperature () const override |
| | Get the minimum temperature the sensor can detect.
| virtual void | SetAmbientTemperature (float _ambient) override |
| | Set the ambient temperature of the environment.
| virtual void | SetAmbientTemperatureRange (float _range) override |
| | Set the range of ambient temperature.
| virtual void | SetHeatSourceTemperatureRange (float _range) override |
| | Set the range of temperature variation for all heat sources. If set, the temperature reading of heat sources will vary within a temperature of +/- range/2 instead of returning a fixed uniform temperature for the entire heat source.
| virtual void | SetLinearResolution (float _resolution) override |
| | Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format.
| virtual void | SetMaxTemperature (float _max) override |
| | Set the maximum temperature the sensor can detect.
| virtual void | SetMinTemperature (float _min) override |
| | Set the minimum temperature the sensor can detect.
| | Destructor.
| virtual | ~Camera () |
| | Destructor.
| | Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns.
| | Renders the current scene using this camera. This function assumes PreRender() has already been called on the parent Scene, allowing the camera and the scene itself to prepare for rendering.
| virtual | ~Sensor () |
| | Sensor.
| | Set visibility mask.
| | Get visibility mask.
| virtual | ~Node () |
| | Destructor.
| | Add the given node to this node. If the given node is already a child, no work will be done.
| | Get node with given ID. If no child exists with given ID, NULL will be returned.
| | Get node at given index. If no child exists at given index, NULL will be returned.
| | Get node with given name. If no child exists with given name, NULL will be returned.
| | Get number of child nodes.
| | Determine if given node is an attached child.
| | Determine if node with given ID is an attached child.
| | Determine if node with given name is an attached child.
| | Determine if this Node is attached to another Node.
| | Check if node has custom data.
| | Determine if this node inherits scale from this parent.
| | Get the initial local pose.
| | Get the local pose.
| | Get the local position.
| | Get the local rotation.
| | Get the local scale.
| | Get position of origin.
| | Get the parent Node.
| | Remove (detach) the given node from this node. If the given node is not a child of this node, no work will be done.
| | Remove (detach) the node with the given ID from this node. If the specified node is not a child of this node, no work will be done.
| | Remove (detach) the node at the given index from this node. If the specified node is not a child of this node, no work will be done.
| | Remove (detach) the node with the given name from this node. If the specified node is not a child of this node, no work will be done.
| | Remove all child nodes from this node This detaches all the child nodes but does not destroy them.
| | Detach this Node from its parent. If this Node does not have a parent, no work will be done.
| | Scale the current scale by the given scalars.
| | Scale the current scale by the given scalar. The given scalar will be assigned to the x, y, and z coordinates.
| | Specify if this node inherits scale from its parent.
| | Set the local pose.
| | Set the local position.
| | Set the local rotation.
| | Set the local scale.
| | Set the local scale. The given scale will be assigned to the x, y, and z coordinates.
| | Set position of origin. The position should be relative to the original origin of the geometry.
| | Store any custom data associated with this node.
| | Set the world pose.
| | Set the world position.
| | Set the world rotation.
| | Set the world scale.
| | Set the world scale. The given scale will be assigned to the x, y, and z coordinates.
| | Get custom data stored in this node.
| | Get the world pose.
| | Get the world position.
| | Get the world rotation.
| | Get the world scale.
| | Convert given world pose to local pose.
| | Destructor.
| | Destroy any resources associated with this object. Invoking any other functions after destroying an object will result in undefined behavior.
| | Get the object ID. This ID will be unique across all objects inside a given scene, but necessarily true for objects across different scenes.
| | Get the object name. This name will be unique across all objects inside a given scene, but necessarily true for objects across different scenes.
| | Get the Scene that created this object.
| virtual | ~BaseCamera () |
| | Add a render pass to the camera.
| | Get the level of anti-aliasing used during rendering.
| | Get the camera's aspect ratio.
| | Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images.
| | Subscribes a new listener to this camera's new frame event.
| | Writes the last rendered image to the given image buffer. This function can be called multiple times after PostRender has been called, without rendering the scene again. Calling this function before a single image has been rendered will have undefined behavior.
| | Created an empty image buffer for capturing images. The resulting image will have sufficient memory allocated for subsequent calls to this camera's Capture function. However, any changes to this cameras properties may invalidate the condition.
| | Create a render window.
| | Get the camera's far clipping plane distance.
| | Get the follow offset vector in the frame specified at the time the follow target is set.
| | Get the camera follow movement P gain.
| | Get the target node being followed.
| | Get the camera's horizontal field-of-view.
| | Get the image pixel format. If the image pixel format has not been set with a valid value, PF_UNKNOWN will be returned.
| | Get the image height in pixels.
| | Get the total image memory size in bytes.
| | Get the image width in pixels.
| | Get the camera's near clipping plane distance.
| | Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed.
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture.
| | Prepare this object and any of its children for rendering. This should be called for each object in a scene just before rendering, which can be achieved by a single call to Scene::PreRender.
| | Project point in 3d world space to 2d screen space.
| | Get the projection matrix for this camera.
| | Get the projection type for this camera.
| | Remove all render passes from the camera.
| | Remove a render pass from the camera.
| | Get a render passes by index.
| | Get the number of render passes applied to the camera.
| | Get the OpenGL texture id associated with the render texture used by this camera. A valid id is returned only if the underlying render engine is OpenGL based.
| | Get the Metal texture id associated with the render texture used by this camera. A valid Id is obtained only if the underlying render engine is Metal based. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease.
| | Writes the previously rendered frame to a file. This function can be called multiple times after PostRender has been called, without rendering the scene again. Calling this function before a single image has been rendered will have undefined behavior.
| | Set the level of anti-aliasing used during rendering. If a value of 0 is given, no anti-aliasing will be performed. Higher values can significantly slow-down rendering times, depending on the underlying render engine.
| | Set the camera's aspect ratio. This value determines the cameras vertical field-of-view. It is often the.
| | Set the camera's far clipping plane distance.
| | Set offset of camera from target node being followed. The offset will be in the frame that is specified at the time the follow target is set.
| | Set follow P Gain. Determines how fast the camera moves to follow the target node. Valid range: [0-1].
| | Set a node for camera to follow. The camera will automatically update its position to keep itself at the specified offset distance from the target being followed. If null is specified, camera follow is disabled. In contrast to SetTrackTarget, the camera does not change its orientation when following is enabled.
| | Set the camera's horizontal field-of-view.
| | Set the image pixel format.
| | Set the image height in pixels.
| | Set the image width in pixels.
| | Set a material that the camera should see on all objects.
| | Set the camera's near clipping plane distance.
| | Set the projection matrix for this camera. This overrides the standard projection matrix computed based on camera parameters.
| | Set the projection type for this camera This changes the projection matrix of the camera based on the camera projection type. A custom projection matrix can be specified via SetProjectionMatrix to override the provided one. To disable the custom projection matrix, just call this function again with the desired projection type.
| | Set track offset. Camera will track a point that's at an offset from the target node. The offset will be in the frame that is specified at the time the track target is set.
| | Set track P Gain. Determines how fast the camera rotates to look at the target node. Valid range: [0-1].
| | Set a node for camera to track. The camera will automatically change its orientation to face the target being tracked. If null is specified, tracking is disabled. In contrast to SetFollowTarget the camera does not change its position when tracking is enabled.
| | Get the track offset vector in the frame specified at the time the track target is set.
| | Get the camera track rotation P gain.
| | Get the target node being tracked.
| | Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images.
| | Get the view matrix for this camera.
| | Get the visual for a given mouse position param[in] _mousePos mouse position.
