ThermalCamera Class Referenceabstract
#include <ThermalCamera.hh>
virtual ~ThermalCamera ()
virtual float AmbientTemperature () const =0
 Get the ambient temperature of the environment.
virtual float AmbientTemperatureRange () const =0
 Get the range of ambient temperature.
virtual gz::common::ConnectionPtr ConnectNewThermalFrame (std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
 Connect to the new thermal image event.
virtual float HeatSourceTemperatureRange () const =0
 Get the range of temperature variation for all heat sources.
virtual float LinearResolution () const =0
 Get the temperature linear resolution.
virtual float MaxTemperature () const =0
 Get the maximum temperature the sensor can detect.
virtual float MinTemperature () const =0
 Get the minimum temperature the sensor can detect.
virtual void SetAmbientTemperature (float _ambient)=0
 Set the ambient temperature of the environment.
virtual void SetAmbientTemperatureRange (float _range)=0
 Set the range of ambient temperature.
virtual void SetHeatSourceTemperatureRange (float _range)=0
 Set the range of temperature variation for all heat sources. If set, the temperature reading of heat sources will vary within a temperature of +/- range/2 instead of returning a fixed uniform temperature for the entire heat source.
virtual void SetLinearResolution (float _resolution)=0
 Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format.
virtual void SetMaxTemperature (float _max)=0
 Set the maximum temperature the sensor can detect.
virtual void SetMinTemperature (float _min)=0
 Set the minimum temperature the sensor can detect.
virtual ~Camera ()
 Create a render window.
virtual void PrepareForExternalSampling ()=0
virtual void Render ()=0
 Get a render passes by index.
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0
 Set the image pixel format.
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~ThermalCamera()
virtual ~ThermalCamera ( )
◆ AmbientTemperature()
virtual float AmbientTemperature ( ) const
Ambient temperature in kelvin
Implemented in BaseThermalCamera< T >, BaseThermalCamera< Ogre2Sensor >, and BaseThermalCamera< OgreSensor >.
◆ AmbientTemperatureRange()
virtual float AmbientTemperatureRange ( ) const
The ambient temperature range. Ambient temperature ranges from (ambient - range/2) to (ambient - range/2)
◆ ConnectNewThermalFrame()
virtual gz::common::ConnectionPtr ConnectNewThermalFrame ( std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberSubscriber callback function. The callback function arguments are: <thermal data, width, height, depth, format>
Implemented in BaseThermalCamera< T >, BaseThermalCamera< Ogre2Sensor >, BaseThermalCamera< OgreSensor >, OgreThermalCamera, and Ogre2ThermalCamera.
◆ HeatSourceTemperatureRange()
virtual float HeatSourceTemperatureRange ( ) const
Temperature variation range
◆ LinearResolution()
virtual float LinearResolution ( ) const
Temperature linear resolution
SetLinearResolution
◆ MaxTemperature()
virtual float MaxTemperature ( ) const
Max temperature in kelvin
SetMaxTemperature
◆ MinTemperature()
virtual float MinTemperature ( ) const
Min temperature in kelvin
SetMinTemperature
◆ SetAmbientTemperature()
virtual void SetAmbientTemperature ( float  _ambient)
[in]_ambientAmbient temperature in kelvin
AmbientTemperature
◆ SetAmbientTemperatureRange()
virtual void SetAmbientTemperatureRange ( float  _range)
[in]_rangeThe ambient temperature ranges from (ambient - range/2) to (ambient + range/2).
◆ SetHeatSourceTemperatureRange()
virtual void SetHeatSourceTemperatureRange ( float  _range)
[in]_rangeTemperature variation range
◆ SetLinearResolution()
virtual void SetLinearResolution ( float  _resolution)
[in]_resolutionTemperature linear resolution
LinearResolution
◆ SetMaxTemperature()
virtual void SetMaxTemperature ( float  _max)
[in]_maxMax temperature in kelvin
MaxTemperature
◆ SetMinTemperature()
virtual void SetMinTemperature ( float  _min)
[in]_minMin temperature in kelvin
MinTemperature
