Ogre2DirectionalLight Class Reference
Ogre 2.x implementation of the directional light class. More...
#include <Ogre2Light.hh>
virtual ~Ogre2DirectionalLight ()
 Get the direction of the light.
- Public Member Functions inherited from BaseDirectionalLight< Ogre2Light >
 ~BaseDirectionalLight () override
void SetDirection (double _x, double _y, double _z) override
- Public Member Functions inherited from DirectionalLight
virtual ~DirectionalLight ()
virtual ~Light ()
virtual ~Ogre2Light ()
 Get the attenuation range.
 Destroy the light.
 Get the diffuse color.
 Get the light intensity.
 Get a pointer to ogre light.
 Set the attenuation range.
 Set the diffuse color.
 Set the light intensity.
 Set the local position.
 Set the specular color.
 Get the specular color.
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
- Protected Member Functions inherited from BaseDirectionalLight< Ogre2Light >
void Reset () override
 Ogre2Light ()
 Initialize the light.
 BaseLight ()
 Ogre2Node ()
 Set the parent node.
double attenConstant = 1.0
 Attenuation constant value.
double attenLinear = 0.0
 Attenuation linear factor.
double attenQuadratic = 0.0
 Attenuation quadratic factor.
double attenRange = 100.0
 Attenuation range.
 Pointer to ogre light.
 Light type.
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2DirectionalLight()
Ogre2DirectionalLight ( )
◆ ~Ogre2DirectionalLight()
virtual ~Ogre2DirectionalLight ( )
◆ Direction()
The direction of the light
Implements DirectionalLight.
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseDirectionalLight< Ogre2Light >.
