Ogre2.x implementation of the render window class. More...
#include <Ogre2RenderTarget.hh>
virtual ~Ogre2RenderWindow ()
virtual bool IsRenderWindow () const override
 Returns true if this is a render window.
virtual Ogre::TextureGpu * RenderTarget () const override
 Get a pointer to the ogre render target containing the results of the render.
- Public Member Functions inherited from BaseRenderWindow< Ogre2RenderTarget >
 BaseRenderWindow ()
 ~BaseRenderWindow () override
double DevicePixelRatio () const override
 Get the device to pixel ratio.
std::string Handle () const override
 Get the window handle that the render window is attached to.
void OnMove () override
 Alert the window of a window move event.
void OnResize (const unsigned int _width, const unsigned int _height) override
 Alert the window of a window resize event.
void SetDevicePixelRatio (const double _ratio) override
 Set the device to pixel ratio.
void SetHandle (const std::string &_handle) override
 Set the window handle to attach the render window to.
- Public Member Functions inherited from RenderWindow
virtual ~RenderWindow ()
virtual ~RenderTarget ()
- Public Member Functions inherited from Ogre2RenderTarget
virtual ~Ogre2RenderTarget ()
 Get the anti-aliasing level.
virtual MaterialPtr BackgroundMaterial () const
 Get the background material of this camera.
 Get a pointer to the internal ogre camera.
 Copy the render target buffer data to an image.
unsigned int GLIdImpl () const
void MetalIdImpl (void *_textureIdPtr) const
void PrepareForExternalSampling ()
 See Camera::PrepareForExternalSampling.
virtual void Render ()
 Main render call.
 set the anti-aliasing level
 Set the background color of the render target.
virtual void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera.
 Set the ogre camera to use for this render target.
 Set a material to render on every object. This method is used for special cases like the render target of a depth camera.
void SetShadowsNodeDefDirty ()
 Set visibility mask for the viewport associated with this render target.
virtual uint32_t VisibilityMask () const
 Get visibility mask for the viewport associated with this render target.
- Public Member Functions inherited from BaseRenderTarget< Ogre2Object >
 BaseRenderTarget ()
 ~BaseRenderTarget () override
virtual bool Reinterpretable () const override
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false) override
virtual void BuildTarget ()
 Build the render window.
 Rebuild the render target.
- Protected Member Functions inherited from Ogre2RenderTarget
virtual void BuildCompositor ()
 Build the compositor.
void BuildTargetImpl ()
 Build the render texture.
virtual void DestroyCompositor ()
 Destroy the compositor.
void DestroyTargetImpl ()
 Destroy the render texture.
virtual void RebuildCompositor ()
 Rebuild the compositor.
 Implementation of the Rebuild function.
void RebuildMaterial ()
 Re-initializes render target material to apply a material to everything in the scene. Does nothing if no material has been set.
Ogre::TextureGpu * RenderTargetImpl () const
 Get a pointer to the ogre render target containing the results of the render (implemented separately to avoid breaking ABI of the pure virtual function)
uint8_t TargetFSAA () const
 Returns the FSAA to use based on supported specs by HW and value specified in Ogre2RenderTarget::AntiAliasing.
 Update the background color.
virtual void UpdateBackgroundMaterial ()
 Update the background material.
 Update the render pass chain.
- Protected Member Functions inherited from BaseRenderTarget< Ogre2Object >
virtual void Rebuild ()
virtual void Init ()
Ogre::TextureGpu * ogreRenderWindow = nullptr
 Pointer to the internal ogre render target object.
- Protected Attributes inherited from BaseRenderWindow< Ogre2RenderTarget >
std::string handle
double ratio
- Protected Attributes inherited from Ogre2RenderTarget
unsigned int antiAliasing = 4
 Anti-aliasing level.
MaterialPtr backgroundMaterial
 Background material of the render target.
bool backgroundMaterialDirty = false
 Flag to indicate if the render target background material has changed.
bool colorDirty = true
 Flag to indicate if the render target color has changed.
 a material used by for the render target
Ogre2RenderTargetMaterialPtr materialApplicator
 Helper class that applies the material to the render target.
 Stores the background color of the render target.
 Pointer to the internal ogre camera.
Ogre::CompositorWorkspace * ogreCompositorWorkspace = nullptr
 Ogre's compositor workspace - the main interface to render into a render target or render texture.
std::string ogreCompositorWorkspaceDefName
 Ogre's compositor workspace definition name.
 visibility mask associated with this render target
- Protected Attributes inherited from BaseRenderTarget< Ogre2Object >
PixelFormat format
unsigned int height
bool reinterpretable
bool renderPassDirty
 Flag to indicate if render pass need to be rebuilt.
 A chain of render passes applied to the render target.
bool targetDirty
unsigned int width
 Pointer to the ogre scene.
- Static Public Member Functions inherited from Ogre2RenderTarget
static uint8_t TargetFSAA (uint8_t _fsaa)
 Returns the FSAA to use based on supported specs by HW and value specified in _fsaa.
static void UpdateRenderPassChain (Ogre::CompositorWorkspace *_workspace, const std::string &_workspaceDefName, const std::string &_baseNode, const std::string &_finalNode, const std::vector< RenderPassPtr > &_renderPasses, bool _recreateNodes, Ogre::TextureGpu *(*_ogreTextures)[2], bool _isRenderWindow)
◆ Ogre2RenderWindow()
Ogre2RenderWindow ( )
◆ ~Ogre2RenderWindow()
virtual ~Ogre2RenderWindow ( )
◆ BuildTarget()
virtual void BuildTarget ( )
◆ IsRenderWindow()
virtual bool IsRenderWindow ( ) const
True if this render target is a render window
Reimplemented from Ogre2RenderTarget.
◆ RebuildTarget()
Implements Ogre2RenderTarget.
◆ RenderTarget()
virtual Ogre::TextureGpu * RenderTarget ( ) const
◆ ogreRenderWindow
Ogre::TextureGpu* ogreRenderWindow = nullptr
