Ogre2RenderPass Class Reference
#include <Ogre2RenderPass.hh>
virtual | ~Ogre2RenderPass () |
Destructor. More... | |
virtual void | CreateRenderPass () |
Create the render pass using ogre compositor. More... | |
void | Destroy () override |
std::string | OgreCompositorNodeDefinitionName () const |
Get the ogre compositor node definition name for this render pass. More... | |
Public Member Functions inherited from BaseRenderPass< Ogre2Object > | |
virtual | ~BaseRenderPass () |
virtual bool | IsEnabled () const override |
Get whether or not the render pass is enabled. More... | |
virtual void | SetEnabled (bool _enabled) override |
Set to enable or disable the render pass. More... | |
Public Member Functions inherited from RenderPass | |
virtual | ~RenderPass () |
virtual bool | IsEnabled () const =0 |
virtual | ~Object () |
virtual | ~Ogre2Object () |
virtual ScenePtr | Scene () const override |
virtual | ~BaseObject () |
virtual unsigned int | Id () const override |
virtual std::string | Name () const override |
virtual void | PostRender () override |
virtual void | PreRender () override |
Ogre2RenderPass () | |
Constructor. More... | |
Protected Member Functions inherited from BaseRenderPass< Ogre2Object > | |
BaseRenderPass () | |
Ogre2Object () | |
BaseObject () | |
virtual void | Init () |
virtual void | Load () |
Protected Attributes | |
std::string | ogreCompositorNodeDefName |
Name of the ogre compositor node definition. More... | |
Protected Attributes inherited from BaseRenderPass< Ogre2Object > | |
bool | enabled |
Flag to indicate if render pass is enabled or not. More... | |
Ogre2ScenePtr | scene |
Pointer to the ogre scene. More... | |
unsigned int | id |
std::string | name |
The ogre2 compositor chain in ign-rendering is set up as follows:
- Base scene pass -> [0..N] RenderPass'es -> Final compositor pass. This is set up by Ogre2RenderTarget which loads the compositor workspace definiton from script. The base scene pass node is responsible for rendering the initial scene and passes its output to any RenderPass'es that are added to the RenderTarget. Each RenderPass has its own ogre compositor node that receives the output from the previous RenderPass as input, applies its own pass over the input, and sends the result to the next RenderPass. Note that the Ogre2RenderPass class provides the node definition only and the actual node creation work is done in the Ogre2RenderTarget class when the whole workspace is constructed.
◆ Ogre2RenderPass()
protected |
◆ ~Ogre2RenderPass()
virtual |
◆ CreateRenderPass()
virtual |
Reimplemented in Ogre2GaussianNoisePass.
◆ Destroy()
overridevirtual |
◆ OgreCompositorNodeDefinitionName()
std::string OgreCompositorNodeDefinitionName | ( | ) | const |
◆ ogreCompositorNodeDefName
protected |
