#include <OgreLight.hh>
virtual ~OgreDirectionalLight ()
virtual math::Vector3d Direction () const
virtual void SetDirection (const math::Vector3d &_dir)
- Public Member Functions inherited from BaseDirectionalLight< OgreLight >
virtual ~BaseDirectionalLight ()
- Public Member Functions inherited from DirectionalLight
virtual ~DirectionalLight ()
virtual ~Light ()
virtual ~OgreLight ()
virtual double AttenuationConstant () const
virtual double AttenuationLinear () const
virtual double AttenuationQuadratic () const
virtual double AttenuationRange () const
virtual bool CastShadows () const
virtual void Destroy ()
virtual math::Color DiffuseColor () const
virtual void SetAttenuationConstant (double _value)
virtual void SetAttenuationLinear (double _value)
virtual void SetAttenuationQuadratic (double _value)
virtual void SetAttenuationRange (double _range)
virtual void SetCastShadows (bool _castShadows)
virtual void SetDiffuseColor (const math::Color &_color)
virtual void SetSpecularColor (const math::Color &_color)
virtual math::Color SpecularColor () const
virtual ~BaseLight ()
virtual ~OgreNode ()
- Protected Member Functions inherited from BaseDirectionalLight< OgreLight >
 OgreLight ()
virtual void Init ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreDirectionalLight()
OgreDirectionalLight ( )
◆ ~OgreDirectionalLight()
virtual ~OgreDirectionalLight ( )
◆ Direction()
The direction of the light
Implements DirectionalLight.
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseDirectionalLight< OgreLight >.
