virtual | ~OgrePointLight () |
virtual | ~BasePointLight () |
virtual | ~PointLight () |
| Deconstructor. More...
virtual | ~Light () |
virtual | ~Node () |
virtual unsigned int | ChildCount () const =0 |
| Get number of child nodes. More...
virtual math::Pose3d | LocalPose () const =0 |
| Get the local pose. More...
virtual math::Vector3d | LocalPosition () const =0 |
| Get the local position. More...
virtual math::Quaterniond | LocalRotation () const =0 |
| Get the local rotation. More...
virtual math::Vector3d | Origin () const =0 |
| Get position of origin. More...
virtual math::Pose3d | WorldPose () const =0 |
| Get the world pose. More...
virtual math::Vector3d | WorldPosition () const =0 |
| Get the world position. More...
virtual math::Quaterniond | WorldRotation () const =0 |
| Get the world rotation. More...
virtual math::Vector3d | WorldScale () const =0 |
| Get the world scale. More...
virtual | ~Object () |
| Destructor. More...
| Get the object ID. This ID will be unique across all objects inside a given scene, but necessarily true for objects across different scenes. More...
| Get the object name. This name will be unique across all objects inside a given scene, but necessarily true for objects across different scenes. More...
| Post process this object and any of its children after rendering. More...
| Get the Scene that created this object. More...
virtual | ~OgreLight () |
virtual double | AttenuationConstant () const |
| Get the attenuation constant value. More...
virtual double | AttenuationLinear () const |
| Get the attenuation linear value. More...
virtual double | AttenuationQuadratic () const |
| Get the attenuation quadratic value. More...
virtual double | AttenuationRange () const |
| Get the attenuation range. More...
virtual bool | CastShadows () const |
| Determine if this light cast shadows. More...
virtual void | Destroy () |
| Destroy any resources associated with this object. Invoking any other functions after destroying an object will result in undefined behavior. More...
virtual math::Color | DiffuseColor () const |
| Get the diffuse color. More...
virtual Ogre::Light * | Light () const |
virtual void | SetAttenuationConstant (double _value) |
| Set the attenuation constant value. More...
virtual void | SetAttenuationLinear (double _value) |
| Set the attenuation linear value. More...
virtual void | SetAttenuationQuadratic (double _value) |
| Set the attenuation quadratic value. More...
virtual void | SetAttenuationRange (double _range) |
| Set the attenuation range. More...
virtual void | SetCastShadows (bool _castShadows) |
| Specify if this light should cast shadows. More...
virtual void | SetDiffuseColor (const math::Color &_color) |
| Set the diffuse color. More...
virtual void | SetSpecularColor (const math::Color &_color) |
| Set the specular color. More...
virtual math::Color | SpecularColor () const |
| Get the specular color. More...
virtual | ~BaseLight () |
virtual void | SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) |
virtual void | SetSpecularColor (double _r, double _g, double _b, double _a=1.0) |
virtual | ~OgreNode () |
virtual bool | HasParent () const override |
| Determine if this Node is attached to another Node. More...
virtual bool | InheritScale () const override |
| Determine if this visual inherits scale from this parent. More...
virtual math::Vector3d | LocalScale () const override |
| Get the local scale. More...
virtual Ogre::SceneNode * | Node () const |
virtual NodePtr | Parent () const override |
| Get the parent Node. More...
virtual void | SetInheritScale (bool _inherit) override |
| Specify if this visual inherits scale from its parent. More...
virtual | ~BaseNode () |
virtual void | AddChild (NodePtr _child) override |
| Add the given node to this node. If the given node is already a child, no work will be done. More...
virtual NodePtr | ChildById (unsigned int _id) const override |
| Get node with given ID. If no child exists with given ID, NULL will be returned. More...
virtual NodePtr | ChildByIndex (unsigned int _index) const override |
| Get node at given index. If no child exists at given index, NULL will be returned. More...
virtual NodePtr | ChildByName (const std::string &_name) const override |
| Get node with given name. If no child exists with given name, NULL will be returned. More...
virtual unsigned int | ChildCount () const override |
virtual bool | HasChild (ConstNodePtr _child) const override |
| Determine if given node is an attached child. More...
virtual bool | HasChildId (unsigned int _id) const override |
| Determine if node with given ID is an attached child. More...
virtual bool | HasChildName (const std::string &_name) const override |
| Determine if node with given name is an attached child. More...
virtual bool | InheritScale () const override=0 |
virtual math::Pose3d | LocalPose () const override |
virtual math::Vector3d | LocalPosition () const override |
virtual math::Quaterniond | LocalRotation () const override |
virtual math::Vector3d | LocalScale () const override=0 |
virtual math::Vector3d | Origin () const override |
virtual NodePtr | Parent () const override=0 |
virtual void | PreRender () override |
| Prepare this object and any of its children for rendering. This should be called for each object in a scene just before rendering, which can be achieved by a single call to Scene::PreRender. More...
virtual NodePtr | RemoveChild (NodePtr _child) override |
| Remove (detach) the given node from this node. If the given node is not a child of this node, no work will be done. More...
virtual NodePtr | RemoveChildById (unsigned int _id) override |
| Remove (detach) the node with the given ID from this node. If the specified node is not a child of this node, no work will be done. More...
virtual NodePtr | RemoveChildByIndex (unsigned int _index) override |
| Remove (detach) the node at the given index from this node. If the specified node is not a child of this node, no work will be done. More...
virtual NodePtr | RemoveChildByName (const std::string &_name) override |
| Remove (detach) the node with the given name from this node. If the specified node is not a child of this node, no work will be done. More...
virtual void | RemoveChildren () override |
| Remove all child nodes from this node This detaches all the child nodes but does not destroy them. More...
virtual void | RemoveParent () override |
| Detach this Node from its parent. If this Node does not have a parent, no work will be done. More...
virtual void | Scale (const math::Vector3d &_scale) override |
| Scale the current scale by the given scalars. More...
virtual void | Scale (double _scale) override |
| Scale the current scale by the given scalar. The given scalar will be assigned to the x, y, and z coordinates. More...
virtual void | Scale (double _x, double _y, double _z) override |
virtual void | SetLocalPose (const math::Pose3d &_pose) override |
| Set the local pose. More...
virtual void | SetLocalPosition (const math::Vector3d &_position) override |
| Set the local position. More...
virtual void | SetLocalPosition (double _x, double _y, double _z) override |
virtual void | SetLocalRotation (const math::Quaterniond &_rotation) override |
| Set the local rotation. More...
virtual void | SetLocalRotation (double _r, double _p, double _y) override |
virtual void | SetLocalRotation (double _w, double _x, double _y, double _z) override |
virtual void | SetLocalScale (const math::Vector3d &_scale) override |
| Set the local scale. More...
virtual void | SetLocalScale (double _scale) override |
| Set the local scale. The given scale will be assigned to the x, y, and z coordinates. More...
virtual void | SetLocalScale (double _x, double _y, double _z) override |
virtual void | SetOrigin (const math::Vector3d &_origin) override |
| Set position of origin. The position should be relative to the original origin of the geometry. More...
virtual void | SetOrigin (double _x, double _y, double _z) override |
virtual void | SetWorldPose (const math::Pose3d &_pose) override |
| Set the world pose. More...
virtual void | SetWorldPosition (const math::Vector3d &_position) override |
| Set the world position. More...
virtual void | SetWorldPosition (double _x, double _y, double _z) override |
virtual void | SetWorldRotation (const math::Quaterniond &_rotation) override |
| Set the world rotation. More...
virtual void | SetWorldRotation (double _r, double _p, double _y) override |
virtual void | SetWorldRotation (double _w, double _x, double _y, double _z) override |
virtual void | SetWorldScale (const math::Vector3d &_scale) override |
| Set the world scale. More...
virtual void | SetWorldScale (double _scale) override |
| Set the world scale. The given scale will be assigned to the x, y, and z coordinates. More...
virtual void | SetWorldScale (double _x, double _y, double _z) override |
virtual math::Pose3d | WorldPose () const override |
virtual math::Vector3d | WorldPosition () const override |
virtual math::Quaterniond | WorldRotation () const override |
virtual math::Vector3d | WorldScale () const override |
virtual math::Pose3d | WorldToLocal (const math::Pose3d &_pose) const override |
| Convert given world pose to local pose. More...
virtual | ~OgreObject () |
virtual ScenePtr | Scene () const |
virtual | ~BaseObject () |
virtual unsigned int | Id () const override |
virtual std::string | Name () const override |
virtual void | PostRender () override |
