ElevatorStateMachineDef Class Reference
Elevator state machine frontend. Defines the transition table and initial state of the state machine. More...
#include <ElevatorStateMachine.hh>
struct  CloseDoorState
 State at which the elevator is closing a door. More...
struct  IdleState
 State at which the elevator is idling. More...
struct  MoveCabinState
 State at which the elevator is moving the cabin to the target floor. More...
struct  OpenDoorState
 State at which the elevator is opening a door. More...
struct  WaitState
 State at which the elevator is waiting with a door open. More...
Public Types
using initial_state = IdleState
 Initial state of the state machine.
using internal_transitions = transition_table< in< events::EnqueueNewTarget, actions::EnqueueNewTarget< true >, guards::IsInState< IdleState > >, in< events::EnqueueNewTarget, actions::EnqueueNewTarget< false >, guards::IsInState< CloseDoorState > > >
 Transition transition table.
using transitions = transition_table< tr< IdleState, events::NewTarget, OpenDoorState, actions::NewTarget, guards::CabinAtTarget >, tr< IdleState, events::NewTarget, MoveCabinState, actions::NewTarget, not_< guards::CabinAtTarget > >, tr< OpenDoorState, events::DoorOpen, WaitState, none, none >, tr< WaitState, events::Timeout, CloseDoorState, none, none >, tr< CloseDoorState, events::DoorClosed, IdleState, none, guards::NoQueuedTarget >, tr< CloseDoorState, events::DoorClosed, MoveCabinState, none, not_< guards::NoQueuedTarget > >, tr< MoveCabinState, events::CabinAtTarget, OpenDoorState, actions::CabinAtTarget, none > >
 Transition table.
 ElevatorStateMachineDef (const std::shared_ptr< ElevatorCommonPrivate > &_system)
 ~ElevatorStateMachineDef ()
Public Attributes
std::unique_ptr< ElevatorStateMachinePrivate > dataPtr
 Public data pointer.
Member Typedef Documentation
◆ initial_state
◆ internal_transitions
◆ transitions
◆ ElevatorStateMachineDef()
ElevatorStateMachineDef ( const std::shared_ptr< ElevatorCommonPrivate > &  _system)
[in]_systemData that are common to both the system and the state machine.
◆ ~ElevatorStateMachineDef()
◆ dataPtr
The documentation for this class was generated from the following files:
