#include <Ogre2AxisVisual.hh>
virtual ~Ogre2AxisVisual ()
- Public Member Functions inherited from BaseAxisVisual< Ogre2Visual >
virtual ~BaseAxisVisual ()
virtual void Init ()
virtual ~AxisVisual ()
virtual ~CompositeVisual ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual MaterialPtr Material () override
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
virtual ~Ogre2Node ()
 Ogre2AxisVisual ()
- Protected Member Functions inherited from BaseAxisVisual< Ogre2Visual >
 BaseAxisVisual ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2AxisVisual()
Ogre2AxisVisual ( )
◆ ~Ogre2AxisVisual()
virtual ~Ogre2AxisVisual ( )
