#include <OgreArrowVisual.hh>
virtual ~OgreArrowVisual ()
- Public Member Functions inherited from BaseArrowVisual< OgreVisual >
virtual ~BaseArrowVisual ()
virtual VisualPtr Head () const
virtual VisualPtr Shaft () const
virtual ~ArrowVisual ()
virtual VisualPtr Head () const =0
virtual VisualPtr Shaft () const =0
virtual ~CompositeVisual ()
virtual ~OgreVisual ()
virtual void SetVisible (bool _visible)
virtual ~BaseVisual ()
virtual MaterialPtr Material () override
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
virtual ~OgreNode ()
 OgreArrowVisual ()
- Protected Member Functions inherited from BaseArrowVisual< OgreVisual >
 BaseArrowVisual ()
virtual void Init ()
 OgreVisual ()
virtual bool AttachGeometry (GeometryPtr _geometry)
virtual bool DetachGeometry (GeometryPtr _geometry)
virtual GeometryStorePtr Geometries () const
 BaseVisual ()
 OgreNode ()
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreArrowVisual()
OgreArrowVisual ( )
◆ ~OgreArrowVisual()
virtual ~OgreArrowVisual ( )
