#include <OgreAxisVisual.hh>
virtual ~OgreAxisVisual ()
- Public Member Functions inherited from BaseAxisVisual< OgreVisual >
virtual ~BaseAxisVisual ()
virtual void Init ()
virtual ~AxisVisual ()
virtual ~CompositeVisual ()
virtual ~OgreVisual ()
virtual void SetVisible (bool _visible)
virtual ~BaseVisual ()
virtual MaterialPtr Material () override
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
virtual ~OgreNode ()
 OgreAxisVisual ()
- Protected Member Functions inherited from BaseAxisVisual< OgreVisual >
 BaseAxisVisual ()
 OgreVisual ()
virtual bool AttachGeometry (GeometryPtr _geometry)
virtual bool DetachGeometry (GeometryPtr _geometry)
virtual GeometryStorePtr Geometries () const
 BaseVisual ()
 OgreNode ()
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreAxisVisual()
OgreAxisVisual ( )
◆ ~OgreAxisVisual()
virtual ~OgreAxisVisual ( )
