#include <OgreGizmoVisual.hh>
virtual ~OgreGizmoVisual ()
- Public Member Functions inherited from BaseGizmoVisual< OgreVisual >
virtual ~BaseGizmoVisual ()
 Reset the gizmo visual state. More...
virtual ~GizmoVisual ()
virtual math::Vector3d ActiveAxis () const =0
virtual TransformMode Mode () const =0
virtual ~CompositeVisual ()
virtual ~OgreVisual ()
virtual void SetVisible (bool _visible)
virtual ~BaseVisual ()
virtual MaterialPtr Material () override
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
virtual ~OgreNode ()
 OgreGizmoVisual ()
- Protected Member Functions inherited from BaseGizmoVisual< OgreVisual >
 BaseGizmoVisual ()
void CreateMaterials ()
 Create materials used by the gizmo visual. More...
void CreateRotationVisual ()
 Create gizmo visual for rotation. More...
void CreateScaleVisual ()
 Create gizmo visual for scale. More...
 Create gizmo visual for translation. More...
 OgreVisual ()
virtual bool AttachGeometry (GeometryPtr _geometry)
virtual bool DetachGeometry (GeometryPtr _geometry)
virtual GeometryStorePtr Geometries () const
 BaseVisual ()
 OgreNode ()
- Protected Types inherited from BaseGizmoVisual< OgreVisual >
enum  AxisMaterial
- Protected Attributes inherited from BaseGizmoVisual< OgreVisual >
VisualPtr activeVis
 Currently active visual. More...
math::Vector3d axis
 Active axis. More...
 A map of gizmo axis and their handle visuals. More...
 A map of axis enums to materials. More...
TransformMode mode
 Current gizmo mode. More...
bool modeDirty
 Flag to indicate the mode has changed. More...
 A map of gizmo axis and their visuals. More...
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreGizmoVisual()
OgreGizmoVisual ( )
◆ ~OgreGizmoVisual()
virtual ~OgreGizmoVisual ( )
