Source Installation on macOS#
This tutorial will work for macOS Sequoia on Apple Silicon (arm64).
Install tools#
The use of some additional tools is recommended to help with the source compilation, although other ways of correctly getting and building the sources are also possible.
The easiest way to get the sources of all libraries is to use vcstool.
To compile all the different libraries and gz-sim in the right order colcon is recommended.
Tools and dependencies for Rotary can be installed using the Homebrew package manager. After installing Homebrew, add the osrf/simulation to Homebrew tap to be able to install prebuilt dependencies.
brew tap osrf/simulation
brew trust osrf/simulation
brew update
Install compiler requirements#
Building Gazebo Libraries requires the Xcode Command Line Tools for your version of macOS. They can be installed with:
xcode-select --install
Python 3 from Homebrew#
Rotary is compatible with Python 3. Install the latest version from Homebrew:
brew install python3
vcstool and colcon from PyPI#
python3 -m venv $HOME/vcs_colcon_installation
. $HOME/vcs_colcon_installation/bin/activate
pip3 install vcstool colcon-common-extensions
Getting the sources#
The first step is to create a developer workspace in which vcstool and colcon can work:
mkdir -p ~/workspace/src
cd ~/workspace/src
All the sources of gazebo-rotary are declared in a yaml file. Download it to the workspace:
curl -OL https://raw.githubusercontent.com/gazebo-tooling/gazebodistro/master/collection-rotary.yaml
Use vcstool to automatically retrieve all the Gazebo libraries sources from their repositories:
vcs import < collection-rotary.yaml
The src subdirectory should contain all the sources ready to be built.
Install dependencies#
Dependency for Ogre:
brew install --cask xquartz
General dependencies:
brew install assimp boost bullet cli11 cmake cppzmq dartsim doxygen eigen fcl ffmpeg flann freeimage freetype gdal gflags google-benchmark ipopt jsoncpp libccd libyaml libzzip libzip nlopt ode open-scene-graph ossp-uuid ogre1.9 gz-rotary-ogre2.3-vendor pkg-config protobuf qt@6 qwt rapidjson ruby tbb tinyxml2 urdfdom zeromq
Building the Gazebo Libraries#
Once the compiler and all the sources are in place it is time to compile them. Start the procedure by changing into the workspace and listing the packages recognized by colcon:
cd ~/workspace/
colcon graph
colcon graph should list the Gazebo libraries with an interdependency diagram. If that is the case, then you are ready to build the whole set of libraries:
colcon build --merge-install --cmake-args -DCMAKE_MACOSX_RPATH=FALSE -DCMAKE_INSTALL_NAME_DIR=$(pwd)/install/lib
Note
The -DCMAKE_MACOSX_RPATH=FALSE and -DCMAKE_INSTALL_NAME_DIR=$(pwd)/install/lib CMake arguments are only needed on Apple Silicon (ARM) Macs and can be omitted on Intel Macs.
To speed up the build process, you could also disable tests by using
colcon build --merge-install --cmake-args -DBUILD_TESTING=OFF -DCMAKE_MACOSX_RPATH=FALSE -DCMAKE_INSTALL_NAME_DIR=$(pwd)/install/lib
To use debuggers activate debug symbols. Gazebo will run slower, but you’ll be able to use lldb:
colcon build --merge-install --cmake-args -DBUILD_TESTING=OFF -DCMAKE_BUILD_TYPE=Debug -DCMAKE_MACOSX_RPATH=FALSE -DCMAKE_INSTALL_NAME_DIR=$(pwd)/install/lib
To build a specific package with all its dependent packages:
colcon build --merge-install --packages-up-to PACKAGE_NAME
To build a single package:
colcon build --merge-install --packages-select PACKAGE_NAME
Visit colcon documentation to view more colcon build and test options.
If there are no errors, all the binaries should be ready to use.
Using the workspace#
The workspace needs to be sourced every time a new terminal is used.
Run the following command to source the workspace in zsh (the default macOS shell):
. ~/workspace/install/setup.zsh
Or if you are using bash:
. ~/workspace/install/setup.bash
You should now be able to launch gazebo:
# launch server in one terminal
gz sim -v 4 shapes.sdf -s
# launch gui in a separate terminal
# remember to source the workspace setup script
gz sim -v 4 -g
This is the end of the source install instructions; head back to the Getting started page to start using Gazebo!
Troubleshooting#
See Troubleshooting
