Binary Installation on Ubuntu#
Rotary binaries are published for Ubuntu Noble (24.04) and Ubuntu
Resolute (26.04) via the nightly
packages repository at packages.osrfoundation.org.
To install all of them, the metapackage gz-rotary can be installed.
Warning
Rotary is a rolling, unstable stream. Packages are updated nightly and breakage is expected. For production use, install a named release such as Jetty instead.
First install some necessary tools:
sudo apt-get update
sudo apt-get install curl lsb-release gnupg
Then install Gazebo Rotary:
sudo curl https://packages.osrfoundation.org/gazebo.gpg --output /usr/share/keyrings/pkgs-osrf-archive-keyring.gpg
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/pkgs-osrf-archive-keyring.gpg] http://packages.osrfoundation.org/gazebo/ubuntu-stable $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/gazebo-stable.list > /dev/null
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/pkgs-osrf-archive-keyring.gpg] http://packages.osrfoundation.org/gazebo/ubuntu-nightly $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/gazebo-nightly.list > /dev/null
sudo apt-get update
sudo apt-get install gz-rotary
All libraries should be ready to use and the gz sim app ready to be executed.
Head back to the Getting started page to start using Gazebo!
Server-only installation#
For headless and CI environments where the GUI is not needed, the
gz-sim-server package provides a lightweight alternative. It installs only
the Gazebo simulation server (gz-sim-server) without any GUI or Qt
dependencies, resulting in a significantly smaller installation footprint.
After configuring the repository (same as above), install the server-only package:
sudo apt-get install gz-sim-server
The server-only package includes the DART physics engine and the core simulation server plugins. To start a headless simulation:
/usr/libexec/gz/sim/gz-sim-server <world_file.sdf>
Note
The server-only binary is installed at /usr/libexec/gz/sim/gz-sim-server,
which is not in the PATH by default. The regular gz sim -s command is not
available in the server-only installation since it requires the full
gz-sim-cli package.
Uninstalling binary install#
If you need to uninstall Gazebo Rotary or switch to a source-based install, run the following command:
sudo apt remove gz-rotary && sudo apt autoremove
Troubleshooting#
See Troubleshooting
