Source Installation on Windows 10 or 11#
Warning
Windows support on Rotary is highly experimental
OGRE2 rendering capabilities are supported in Windows, and Gazebo GUI works in a limited fashion. These functionalities correspond to the currently building packages gz-rendering and gz-sim, respectively. The packages will build, without any failures when using their functionalities.
NOTE You should be able to use ogre as a rendering engine instead of the default ogre2. Just append --render-engine ogre to the command line.
Dependency distribution (conda-forge) and the package manager (Pixi)#
Binaries for all the dependencies used by Gazebo can be found in the conda-forge package repository. The Gazebo buildfarm and these instructions uses the Pixi package manager but other package managers for Conda should work like miniforge, mamba, etc.
Install dependencies#
  1. If no package manager is installed in the system to manage conda-forge dependencies, the recommended option is to follow the Pixi installer instructions from https://pixi.sh/latest/ to install pixi. Once pixi has been installed, close the terminal session and start it again, which will ensure pixi is on the PATH.
  2. Install Visual Studio 2019 or 2022. The Community version is free for students, open-source developers, and personal development. Check “Desktop development with C++” in the Workloads tab, check “MFC and ATL support”, and uncheck “C++ Cmake Tools.” We will install cmake via Conda. All other checkboxes can be left unchecked.
  3. Open a Visual Studio Command Prompt (search for “x64 Native Tools Command Prompt for VS” in the Windows search field near the Windows button) or Developer PowerShell for VS (search for “developer powershell”). Optionally, right-click and pin to the task bar for quick access in the future.
  4. Create the Pixi project directory and download the configuration files Pixi projects operates inside a given directory, creating one in any user system location should be enough. There are two configuration files to download:
    mkdir gazebo
    cd gazebo
    curl.exe -L -O https://raw.githubusercontent.com/gazebo-tooling/release-tools/refs/heads/master/conda/envs/noble_like/pixi.toml
    curl.exe -L -O https://raw.githubusercontent.com/gazebo-tooling/release-tools/refs/heads/master/conda/envs/noble_like/pixi.lock
  5. Install dependencies using Pixi and enable the Pixi environment: Once inside the Pixi project directory (i.e: gazebo), Pixi can install the dependencies that are part of the configuration file:
    :: inside the gazebo directory
    pixi install
    This can take some minutes. After this Pixi can make accessible all the libraries and dependencies installed by providing a shell environment:
    pixi shell
    With the Pixi shell environment active (there will be a “(gazebo)” label before the terminal prompt) the Pixi environment is accessible from anywhere in the file system.
  6. Navigate to where you would like to build the library, create and enter your workspace directory, create the src directory which will contain the Gazebo source code.
    mkdir gz-ws
    cd gz-ws
    mkdir src
  7. Then clone the repositories
    vcs import --input https://raw.githubusercontent.com/gazebo-tooling/gazebodistro/master/collection-rotary.yaml src/
Building the Gazebo Libraries#
Note
Be sure of being under a Visual Studio Developer shell (step 3 above) and after executing the pixi shell (step 5 above).
Once the compiler and all the sources are in place it is time to compile them. Start the procedure by navigating to your workspace and listing the packages recognized by colcon:
colcon graph
colcon graph should list the Gazebo libraries with an interdependency diagram. If that is the case, then you are ready to build the whole set of libraries:
colcon build --cmake-args -DBUILD_TESTING=OFF -DSKIP_SWIG=ON --merge-install --packages-up-to gz-sim gz-tools
Tests are turned off as they are not currently supported on Windows.
To build a specific package with all its dependent packages:
colcon build --merge-install --packages-up-to PACKAGE_NAME
To build a single package:
colcon build --packages-select PACKAGE_NAME
Visit colcon documentation to view more colcon build and test options.
If there are no errors, all the binaries should be ready to use.
Using the workspace#
The workspace needs to be sourced every time a new terminal is used ( and the Pixi environment activated before that).
The overall instructions for setting up a new terminal to use the built workspace are:
# CMD
cd gazebo
pixi shell
call gz-ws\install\setup.bat
# PowerShell
cd gazebo
pixi shell
.\gz-ws\install\setup.ps1
You should now be able to launch gazebo normally:
gz sim --verbose
Alternativally launching the server and the client in two different terminales (after sourcing in both the install scripts, the pixi shell and the QT env variables):
# Launch server in one terminal
gz sim -s
# In separate terminal, launch gui
gz sim -g
This is the end of the source install instructions; head back to the Getting started page to start using Gazebo!
NOTE If your username contains spaces (which is quite common on Windows), you will probably get errors saying Invalid partition name [Computer:My User With Spaces]. Fix this by changing GZ_PARTITION to something else:
set GZ_PARTITION=test
Remember to set the same partition in all other consoles.
Note
On Windows, Python from conda-forge provides python.exe but no python3.exe, so python3 does not run the Python from this environment (it may open the Microsoft Store instead). When a tutorial uses python3, run the same command with python.
Uninstalling source-based install#
A source-based install can be “uninstalled” using several methods, depending on the results you want:
  1. If you installed your workspace with colcon as instructed above, “uninstalling” could be just a matter of opening a new terminal and not sourcing the workspace’s setup.bat. This way, your environment will behave as though Gazebo is not installed on your system.
  2. If, in addition to not wanting to use the libraries, you’re also trying to free up space, you can delete the entire workspace directory from within your conda environment with:
    rmdir /s /q <workspace_name>  # gz-ws was used as workspace_name in this document
  3. If you want to keep the source code, you can remove the install / build / log directories as desired, leaving the src directory.
  4. Last, if you do not need the Pixi environment anymore, you can remove it with
    rmdir /s /q <pixi_env_path>  # "gazebo" was used as pixi_env_path in this document
Troubleshooting#
See Troubleshooting
