Use ROS 2 Simulation Interfaces to Interact with Gazebo#
The ROS 2 Simulation Interfaces define a standard set of ROS 2 service, message and action definitions for controlling and interacting with simulation environments. These interfaces are simulator-agnostic and aim to provide a unified way to control and observe simulation using ROS 2.
Gazebo has implemented these interfaces, enabling tasks like spawning entities, stepping simulation, querying world state, etc. through standard ROS 2 calls. In this tutorial we will learn how to interact with a running Gazebo simulation for the following tasks,
Simulation Control#
The following services and actions are available to control the flow of simulation time.
Interface Name
Topic Name
Type
Description
ResetSimulation
/gzserver/reset_simulation
Service
Reset the simulation to its initial state
StepSimulation
/gzserver/step_simulation
Service
Step the simulation forward by a specified number of steps
GetSimulationState
/gzserver/get_simulation_state
Service
Get the current simulation state (playing/paused/stopped)
SetSimulationState
/gzserver/set_simulation_state
Service
Set the simulation state (play/pause/stop)
SimulateSteps
/gzserver/simulate_steps
Action
Step the simulation forward by a specified number of steps with feedback and cancellation support
ResetSimulation Service#
Reset the simulation to its initial state.
ros2 service call /gzserver/reset_simulation simulation_interfaces/srv/ResetSimulation "{}"
StepSimulation Service#
Step the simulation forward by a specified number of steps.
ros2 service call /gzserver/step_simulation simulation_interfaces/srv/StepSimulation "{steps: 10}"
GetSimulationState Service#
Get the current simulation state (playing/paused/stopped).
ros2 service call /gzserver/get_simulation_state simulation_interfaces/srv/GetSimulationState "{}"
SetSimulationState Service#
Set the simulation state (play/pause/stop).
  • Set simulation state to stop.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 0}}"
  • Set simulation state to playing.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 1}}"
  • Set simulation state to paused.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 2}}"
  • Set simulation state to quitting.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 3}}"
SimulateSteps Action#
Step the simulation forward by a specified number of steps with feedback and cancellation support.
ros2 action send_goal /gzserver/simulate_steps simulation_interfaces/action/SimulateSteps "{steps: 10}" --feedback
Entity Management#
The following interfaces are used to create or remove entities in the simulation at runtime.
Interface Name
Topic Name
Type
Description
SpawnEntity
/gzserver/spawn_entity
Service
Spawn a new entity in the simulation at a specific location
DeleteEntity
/gzserver/delete_entity
Service
Delete an existing entity by name
SpawnEntity Service#
Spawn a new entity in the simulation at a specific location.
ros2 service call /gzserver/spawn_entity simulation_interfaces/srv/SpawnEntity "{
  entity_resource: {
    uri: '/path/to/model.sdf'
  allow_renaming: false,
  initial_pose: {
    pose: {
      position: {x: 0.0, y: 0.0, z: 0.0},
      orientation: {w: 1.0, x: 0.0, y: 0.0, z: 0.0}
DeleteEntity Service#
Delete an existing entity by name.
ros2 service call /gzserver/delete_entity simulation_interfaces/srv/DeleteEntity "{entity: 'my_model'}"
State Query#
The following interfaces are used to introspect simulation world and entity state.
Interface Name
Topic Name
Type
Description
GetEntityState
/gzserver/get_entity_state
Service
Get the pose and twist of a specific entity
GetEntitiesStates
/gzserver/get_entities_states
Service
Get the state for multiple entities (optionally filtered)
GetEntities
Service
Get a list of entities (optionally filtered)
GetEntityState Service#
Get the pose and twist of a specific entity.
ros2 service call /gzserver/get_entity_state simulation_interfaces/srv/GetEntityState "{entity: 'my_model'}"
GetEntitiesStates Service#
Get the state of multiple entities (optionally filtered).
ros2 service call /gzserver/get_entities_states simulation_interfaces/srv/GetEntitiesStates "{filters: {filter: ''}}"
GetEntites Service#
Get the list of entities (optionally filtered).
ros2 service call /gzserver/get_entities simulation_interfaces/src/GetEntities "{filters: {filter: ''}}"
State Update#
The following interfaces are used to set entity states.
Interface Name
Topic Name
Type
Description
SetEntityState
/gzserver/set_entity_state
Service
Set the pose and twist of a specific entity
SetEntityState Service#
Set the pose and twist of a specific entity.
ros2 service call /gzserver/set_entity_state simulation_interfaces/srv/SetEntityState "{ entity: 'my_model', state: {pose: { position: { x: -2.0, z: 0.5 }}, twist: {linear: {x: 0.5}}}}"
Caution
When using SetEntityState, it is currently not possible to set just the pose or the twist of an entity. Both components of the entity will be assigned based on the value of the provided message. For example, of pose is left empty, the pose of the entity will be set to the origin.
This might be resolved in the future. See ros-simulation/simulation_interfaces#18
Simulator Information#
Some simulators may only support a subset of interfaces. The following services can be used to inspect supported features.
Interface Name
Topic Name
Type
Description
GetSimulatorFeatures
/gzserver/get_simulator_features
Service
Query which interface features are supported
GetSimulatorFeatures Service#
Query which interface features are supported.
ros2 service call /gzserver/get_simulator_features simulation_interfaces/srv/GetSimulationFeatures "{}"
Dependencies and Troubleshooting#
Required Gazebo Systems#
Gazebo’s ROS 2 Simulation Interfaces rely on Gazebo Transport topics and services exposed by Gazebo’s world systems rather than reading simulation state directly. In particular, SceneBroadcaster (gz::sim::systems::SceneBroadcaster) is required to synchronize world state and detect simulation resets.
Warning
By default, SceneBroadcaster, UserCommands, and Physics are loaded automatically from Gazebo’s server configuration (server.config or GZ_SIM_SERVER_CONFIG_PATH). However, if your world SDF disables server config plugins via <gz:policies><include_server_config_plugins>false</include_server_config_plugins></gz:policies> (while loading other world plugins) or if you use a custom GZ_SIM_SERVER_CONFIG_PATH that omits default systems, you must explicitly include:
  • gz::sim::systems::SceneBroadcaster — required for state synchronization and reset detection. Without it, initialization fails and state-dependent calls return RESULT_OPERATION_FAILED ("Required Gazebo system is missing").
  • gz::sim::systems::UserCommands — required by SpawnEntity and DeleteEntity.
  • gz::sim::systems::Physics — required to compute dynamic entity poses and velocities for GetEntityState and SetEntityState.
Update Rates, Latency, and Timeouts#
  • Nominal update rates and service latency: Most simulation_interfaces services wait for the next state update on SceneBroadcaster’s /world/<world>/state topic before responding. By default, SceneBroadcaster throttles these updates in wall-clock time to 60 Hz (~16.7 ms period) when simulation is running and 30 Hz (~33.3 ms period, half of the running rate) when paused. Expect up to one broadcast period of latency on these calls (including GetSimulationState and SetSimulationState, which read pause/iteration status from /world/<world>/stats but still synchronize with SceneBroadcaster).
  • Event-triggered (off-rate) updates: In addition to its periodic schedule, SceneBroadcaster immediately publishes an extra state message whenever simulation events occur, such as spawning or deleting entities, setting entity poses/twists, removing components, or resetting/rewinding time. During active events, the state publish rate can temporarily exceed 60 Hz / 30 Hz and service calls may unblock sooner than one nominal period.
  • Avoid setting <state_hertz> too low: If you override <state_hertz> on the SceneBroadcaster plugin in your SDF, keep in mind that the paused rate is half of <state_hertz> and simulation_interfaces times out after 1 second (1000 ms) while waiting for the next state message. Setting <state_hertz> ≤ 2.0 (when paused) or ≤ 1.0 (when running) can cause calls to fail with "Timed out while waiting for updated Gazebo state" whenever no simulation events occur.
  • Stepping feedback rate: StepSimulation and the SimulateSteps action track completed steps from /world/<world>/stats, which Gazebo publishes at 10 Hz (100 ms period) independently of SceneBroadcaster.
Common Issues and Quirks#
  • Brief delay querying velocities after spawning an entity: Right after SpawnEntity succeeds, velocity tracking is enabled on the new model’s canonical link via /world/<world>/control/state. Calling GetEntityState immediately before the server processes that update, steps physics, and broadcasts the next state can temporarily fail or report zero velocity. Enabling velocity tracking on all canonical links can also add overhead in worlds with many models.
  • Avoid spawning entities concurrently with ResetSimulation: Reset completion is detected through /world/<world>/scene/info, which SceneBroadcaster also publishes whenever a new entity is added to the world. Spawning an entity at the same time as ResetSimulation can cause reset detection to trigger early.
  • Ensure the server steps on startup in custom setups: SceneBroadcaster only advertises its state topic and service after the first simulation update step, and initial state synchronization blocks until a step runs. The gzserver node handles this automatically; if you embed the simulation interfaces alongside a custom gz::sim::Server, make sure the server executes an initial step or is already running.
  • Single-world and top-level model scope: Only the first world reported by Gazebo (/gazebo/worlds) is managed. GetEntities and GetEntitiesStates return top-level models only (nested models are excluded), and GetEntityState expects a model entity.
Known Limitations#
  • Only an empty string or “world” can be used in the frame_id field of PoseStamped messages. We plan to add support for using frames known to Tf in the future.
  • Entity namespaces are not supported by the SpawnEntity service.
  • When spawning an entity, if SpawnEntity.allow_renaming is set to true and a rename occurs in Gazebo, the new name is not returned in the Result object return by the SpawnEntity service.
