#include <Ogre2GizmoVisual.hh>
virtual ~Ogre2GizmoVisual ()
- Public Member Functions inherited from BaseGizmoVisual< Ogre2Visual >
virtual ~BaseGizmoVisual ()
 Get the current active axis.
 Get the Transform axis associated with the given id.
 Get the child visual by axis.
virtual void LookAt (const math::Vector3d &_pos, const math::Quaterniond &_rot) override
 Update the Gizmo visual's rotation visuals to face the specified position.
 Get the current transform mode.
 Reset the gizmo visual state.
 Set the active axis in the gizmo visual.
 Set the transform mode of the gizmo. This controls the visual appearance of the gizmo. Only the visuals in the specified mode will be visible, e.g. if set to TM_TRANSLATION mode, then only the translation axis visuals will be visible.
virtual ~GizmoVisual ()
virtual ~CompositeVisual ()
virtual ~Ogre2Visual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 Ogre2GizmoVisual ()
- Protected Member Functions inherited from BaseGizmoVisual< Ogre2Visual >
 BaseGizmoVisual ()
void CreateMaterials ()
 Create materials used by the gizmo visual.
void CreateRotationVisual ()
 Create gizmo visual for rotation.
void CreateScaleVisual ()
 Create gizmo visual for scale.
 Create gizmo visual for translation.
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node.
- Protected Types inherited from BaseGizmoVisual< Ogre2Visual >
enum  AxisMaterial
- Protected Attributes inherited from BaseGizmoVisual< Ogre2Visual >
VisualPtr activeVis
 Currently active visual.
math::Vector3d axis
 Active axis.
 A map of gizmo axis and their handle visuals.
 A map of axis enums to materials.
TransformMode mode
 Current gizmo mode.
bool modeDirty
 Flag to indicate the mode has changed.
 A map of gizmo axis and their visuals.
 Pointer to the attached geometries.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2GizmoVisual()
Ogre2GizmoVisual ( )
◆ ~Ogre2GizmoVisual()
virtual ~Ogre2GizmoVisual ( )
