#include <OgreAxisVisual.hh>
virtual ~OgreAxisVisual ()
- Public Member Functions inherited from BaseAxisVisual< OgreVisual >
virtual ~BaseAxisVisual ()
 Get the local scale.
 Set the local scale.
 set true to show the axis heads, false otherwise
 set true to show the specified axis head, false otherwise
virtual ~AxisVisual ()
virtual ~CompositeVisual ()
virtual ~OgreVisual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~OgreNode ()
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreAxisVisual ()
- Protected Member Functions inherited from BaseAxisVisual< OgreVisual >
 BaseAxisVisual ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreAxisVisual()
OgreAxisVisual ( )
◆ ~OgreAxisVisual()
virtual ~OgreAxisVisual ( )
