#include <OgreLight.hh>
virtual ~OgrePointLight ()
- Public Member Functions inherited from BasePointLight< OgreLight >
virtual ~BasePointLight ()
- Public Member Functions inherited from PointLight
virtual ~PointLight ()
virtual ~Light ()
 ~OgreLight () override
 Get the attenuation range.
 Get the diffuse color.
 Get the light intensity.
void SetAttenuationConstant (double _value) override
void SetAttenuationLinear (double _value) override
void SetAttenuationQuadratic (double _value) override
void SetAttenuationRange (double _range) override
 Set the attenuation range.
void SetCastShadows (bool _castShadows) override
void SetDiffuseColor (const math::Color &_color) override
 Set the diffuse color.
 Set the light intensity.
void SetSpecularColor (const math::Color &_color) override
 Set the specular color.
 Get the specular color.
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgrePointLight ()
- Protected Member Functions inherited from BasePointLight< OgreLight >
 BasePointLight ()
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgrePointLight()
OgrePointLight ( )
◆ ~OgrePointLight()
virtual ~OgrePointLight ( )
