gz/rendering/RenderTypes.hh
17 #ifndef GZ_RENDERING_RENDERTYPES_HH_
18 #define GZ_RENDERING_RENDERTYPES_HH_
20 #include <memory>
21 #include <gz/rendering/config.hh>
22
23
26 #define IGN_VISIBILITY_ALL 0x0FFFFFFF
27
30 #define IGN_VISIBILITY_SELECTION 0x10000000
31
34 #define IGN_VISIBILITY_GUI 0x00000001
35
38 #define IGN_VISIBILITY_SELECTABLE 0x00000002
39
40 namespace ignition
41 {
42  namespace rendering
43  {
44  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
45  //
46  template <class T>
48
49  class ArrowVisual;
50  class AxisVisual;
51  class BoundingBoxCamera;
52  class Camera;
53  class Capsule;
54  class COMVisual;
55  class DepthCamera;
56  class DirectionalLight;
57  class DistortionPass;
58  class GaussianNoisePass;
59  class Geometry;
60  class GizmoVisual;
61  class GpuRays;
62  class Grid;
63  class Heightmap;
64  class Image;
65  class InertiaVisual;
66  class Light;
67  class LightVisual;
68  class JointVisual;
69  class LidarVisual;
70  class Light;
71  class Marker;
72  class Material;
73  class Mesh;
74  class Node;
75  class Object;
76  class ObjectFactory;
77  class ParticleEmitter;
78  class PointLight;
79  class RayQuery;
80  class RenderEngine;
81  class RenderPass;
82  class RenderPassSystem;
83  class RenderTarget;
84  class RenderTexture;
85  class RenderWindow;
86  class Scene;
87  class SegmentationCamera;
88  class Sensor;
89  class ShaderParams;
90  class SpotLight;
91  class SubMesh;
92  class Text;
93  class ThermalCamera;
94  class Visual;
95  class WireBox;
96
100
104
108
112
116
120
124
128
132
136
140
144
148
152
156
160
164
168
172
176
180
184
188
192
196
200
204
208
212
216
220
224
228
232
236
240
247
251
254
258
262
266
270
274
278
282
286
290
294
298
302
306
310
314
318
322
326
330
334
338
342
346
350
354
358
362
366
370
374
378
382
386
390
394
398
402
405
409
413
417
421  }
422  }
423 }
424 #endif
Represents a arrow composite visual.
Definition: gz/rendering/ArrowVisual.hh:33
Represents a axis composite visual.
Definition: gz/rendering/AxisVisual.hh:33
Poseable BoundingBox camera used for rendering bounding boxes of objects in the scene.
Definition: gz/rendering/BoundingBoxCamera.hh:56
Represents a center of mass visual.
Definition: gz/rendering/COMVisual.hh:38
Definition: gz/rendering/Camera.hh:52
Geometry for a capsule shape.
Definition: gz/rendering/Capsule.hh:34
Definition: gz/rendering/DepthCamera.hh:36
Represents a infinite directional light.
Definition: gz/rendering/Light.hh:123
A render pass that applies distortion to the render target.
Definition: gz/rendering/DistortionPass.hh:39
A render pass that applies Gaussian noise to the render target.
Definition: gz/rendering/GaussianNoisePass.hh:37
Represents a geometric shape to be rendered.
Definition: gz/rendering/Geometry.hh:36
A gizmo that contains rotate, translate, and scale visuals.
Definition: gz/rendering/GizmoVisual.hh:36
Generate depth ray data.
Definition: gz/rendering/GpuRays.hh:39
Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the gri...
Definition: gz/rendering/Grid.hh:36
A terrain defined by a heightfield.
Definition: gz/rendering/Heightmap.hh:34
Definition: gz/rendering/Image.hh:40
Represents a inertia visual.
Definition: gz/rendering/InertiaVisual.hh:37
Represents a joint visual.
Definition: gz/rendering/JointVisual.hh:71
A LidarVisual geometry class. The visual appearance is based on the type specified.
Definition: gz/rendering/LidarVisual.hh:57
Represents a light visual.
Definition: gz/rendering/LightVisual.hh:51
Represents a light source in the scene graph.
Definition: gz/rendering/Light.hh:34
A marker geometry class. The marker's visual appearance is based on the marker type specified.
Definition: gz/rendering/Marker.hh:79
Definition: gz/rendering/Material.hh:49
Represents a collection of mesh geometries.
Definition: gz/rendering/Mesh.hh:39
Definition: gz/rendering/Node.hh:53
Definition: gz/rendering/Object.hh:35
Class to manage a particle emitter.
Definition: gz/rendering/ParticleEmitter.hh:60
Represents a point light.
Definition: gz/rendering/Light.hh:146
A Ray Query class used for computing ray object intersections.
Definition: gz/rendering/RayQuery.hh:65
Definition: gz/rendering/RenderEngine.hh:37
A class for creating and managing render passes.
Definition: gz/rendering/RenderPassSystem.hh:57
A render pass can be added to a camera to affect how the scene is rendered. It can be used to add pos...
Definition: gz/rendering/RenderPass.hh:36
Definition: gz/rendering/RenderTarget.hh:39
Represents a off-screen render-texture to which cameras can render images.
Definition: gz/rendering/RenderTarget.hh:105
Represents a on-screen render-window to which cameras can render images.
Definition: gz/rendering/RenderTarget.hh:121
Definition: gz/rendering/Scene.hh:50
Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce s...
Definition: gz/rendering/SegmentationCamera.hh:53
Definition: gz/rendering/Sensor.hh:34
a map that holds params to be passed to a shader
Definition: gz/rendering/ShaderParams.hh:39
Represents a spotlight.
Definition: gz/rendering/Light.hh:155
Represents a single mesh geometry.
Definition: gz/rendering/Mesh.hh:138
Represents a billboard text geometry that is always facing the camera.
Definition: gz/rendering/Text.hh:64
Thermal camera that produces temperature data. An object's temperature can be set through the Visual ...
Definition: gz/rendering/ThermalCamera.hh:42
Definition: gz/rendering/Visual.hh:35
Draws a wireframe box.
Definition: gz/rendering/WireBox.hh:34
shared_ptr< const BoundingBoxCamera > ConstBoundingBoxCameraPtr
Definition: gz/rendering/RenderTypes.hh:297
shared_ptr< Image > ImagePtr
Shared pointer to Image.
Definition: gz/rendering/RenderTypes.hh:167
shared_ptr< Node > NodePtr
Shared pointer to Node.
Definition: gz/rendering/RenderTypes.hh:203
shared_ptr< const RenderTexture > ConstRenderTexturePtr
Definition: gz/rendering/RenderTypes.hh:389
shared_ptr< const ArrowVisual > ConstArrowVisualPtr
Definition: gz/rendering/RenderTypes.hh:277
shared_ptr< LidarVisual > LidarVisualPtr
Shared pointer to LidarVisual.
Definition: gz/rendering/RenderTypes.hh:187
shared_ptr< RayQuery > RayQueryPtr
Shared pointer to RayQuery.
Definition: gz/rendering/RenderTypes.hh:223
shared_ptr< const GaussianNoisePass > ConstGaussianNoisePass
Shared pointer to const GaussianNoisePass.
Definition: gz/rendering/RenderTypes.hh:313
shared_ptr< const Visual > ConstVisualPtr
Definition: gz/rendering/RenderTypes.hh:420
shared_ptr< const LidarVisual > ConstLidarVisualPtr
Definition: gz/rendering/RenderTypes.hh:341
shared_ptr< Text > TextPtr
Shared pointer to Text.
Definition: gz/rendering/RenderTypes.hh:265
shared_ptr< Capsule > CapsulePtr
Shared pointer to Capsule.
Definition: gz/rendering/RenderTypes.hh:151
shared_ptr< const Scene > ConstScenePtr
Definition: gz/rendering/RenderTypes.hh:397
shared_ptr< Scene > ScenePtr
Shared pointer to Scene.
Definition: gz/rendering/RenderTypes.hh:246
shared_ptr< const RenderPass > ConstRenderPassPtr
Definition: gz/rendering/RenderTypes.hh:377
shared_ptr< const Light > ConstLightPtr
Definition: gz/rendering/RenderTypes.hh:337
shared_ptr< const SubMesh > ConstSubMeshPtr
Definition: gz/rendering/RenderTypes.hh:412
shared_ptr< const DirectionalLight > ConstDirectionalLightPtr
Definition: gz/rendering/RenderTypes.hh:309
shared_ptr< GaussianNoisePass > GaussianNoisePassPtr
Shared pointer to GaussianNoisePass.
Definition: gz/rendering/RenderTypes.hh:139
shared_ptr< const Image > ConstImagePtr
Definition: gz/rendering/RenderTypes.hh:333
shared_ptr< Geometry > GeometryPtr
Shared pointer to Geometry.
Definition: gz/rendering/RenderTypes.hh:143
shared_ptr< RenderTexture > RenderTexturePtr
Shared pointer to RenderTexture.
Definition: gz/rendering/RenderTypes.hh:239
shared_ptr< BoundingBoxCamera > BoundingBoxCameraPtr
Shared pointer to BoundingBoxCamera.
Definition: gz/rendering/RenderTypes.hh:119
shared_ptr< AxisVisual > AxisVisualPtr
Shared pointer to AxisVisual.
Definition: gz/rendering/RenderTypes.hh:103
shared_ptr< SubMesh > SubMeshPtr
Shared pointer to SubMesh.
Definition: gz/rendering/RenderTypes.hh:261
shared_ptr< const Camera > ConstCameraPtr
Definition: gz/rendering/RenderTypes.hh:285
shared_ptr< const Mesh > ConstMeshPtr
Definition: gz/rendering/RenderTypes.hh:349
shared_ptr< ParticleEmitter > ParticleEmitterPtr
Shared pointer to ParticleEmitter.
Definition: gz/rendering/RenderTypes.hh:215
shared_ptr< const Node > ConstNodePtr
Definition: gz/rendering/RenderTypes.hh:353
shared_ptr< Marker > MarkerPtr
Shared pointer to Marker.
Definition: gz/rendering/RenderTypes.hh:195
shared_ptr< Object > ObjectPtr
Shared pointer to Object.
Definition: gz/rendering/RenderTypes.hh:207
shared_ptr< GpuRays > GpuRaysPtr
Shared pointer to GpuRays.
Definition: gz/rendering/RenderTypes.hh:127
shared_ptr< JointVisual > JointVisualPtr
Shared pointer to JointVisual.
Definition: gz/rendering/RenderTypes.hh:159
shared_ptr< const RenderPassSystem > ConstRenderPassSystemPtr
Definition: gz/rendering/RenderTypes.hh:381
shared_ptr< ShaderParams > ShaderParamsPtr
Shared pointer to ShaderParams.
Definition: gz/rendering/RenderTypes.hh:253
shared_ptr< ThermalCamera > ThermalCameraPtr
Shared pointer to ThermalCamera.
Definition: gz/rendering/RenderTypes.hh:115
shared_ptr< Sensor > SensorPtr
Shared pointer to Sensor.
Definition: gz/rendering/RenderTypes.hh:250
shared_ptr< const RenderTarget > ConstRenderTargetPtr
Definition: gz/rendering/RenderTypes.hh:385
shared_ptr< DepthCamera > DepthCameraPtr
Shared pointer to DepthCamera.
Definition: gz/rendering/RenderTypes.hh:111
shared_ptr< const ShaderParams > ConstShaderParamsPtr
Shared pointer to const ShaderParams.
Definition: gz/rendering/RenderTypes.hh:404
shared_ptr< const Heightmap > ConstHeightmapPtr
Definition: gz/rendering/RenderTypes.hh:329
shared_ptr< const RenderWindow > ConstRenderWindowPtr
Definition: gz/rendering/RenderTypes.hh:393
shared_ptr< const Text > ConstTextPtr
Definition: gz/rendering/RenderTypes.hh:416
shared_ptr< SegmentationCamera > SegmentationCameraPtr
Shared pointer to Segmentation Camera.
Definition: gz/rendering/RenderTypes.hh:123
shared_ptr< const JointVisual > ConstJointVisualPtr
Definition: gz/rendering/RenderTypes.hh:325
shared_ptr< DistortionPass > DistortionPassPtr
Shared pointer to DistortionPass.
Definition: gz/rendering/RenderTypes.hh:135
shared_ptr< const SegmentationCamera > ConstSegmentationCameraPtr
Definition: gz/rendering/RenderTypes.hh:301
shared_ptr< const ThermalCamera > ConstThermalCameraPtr
Definition: gz/rendering/RenderTypes.hh:293
shared_ptr< Light > LightPtr
Shared pointer to Light.
Definition: gz/rendering/RenderTypes.hh:175
shared_ptr< Material > MaterialPtr
Shared pointer to Material.
Definition: gz/rendering/RenderTypes.hh:191
shared_ptr< const Geometry > ConstGeometryPtr
Definition: gz/rendering/RenderTypes.hh:317
shared_ptr< ArrowVisual > ArrowVisualPtr
Shared pointer to ArrowVisual.
Definition: gz/rendering/RenderTypes.hh:99
shared_ptr< RenderPass > RenderPassPtr
Shared pointer to RenderPass.
Definition: gz/rendering/RenderTypes.hh:227
shared_ptr< RenderTarget > RenderTargetPtr
Shared pointer to RenderTarget.
Definition: gz/rendering/RenderTypes.hh:235
shared_ptr< GizmoVisual > GizmoVisualPtr
Shared pointer to GizmoVisual.
Definition: gz/rendering/RenderTypes.hh:147
shared_ptr< WireBox > WireBoxPtr
Shared pointer to WireBox.
Definition: gz/rendering/RenderTypes.hh:273
shared_ptr< DirectionalLight > DirectionalLightPtr
Shared pointer to DirectionalLight.
Definition: gz/rendering/RenderTypes.hh:131
shared_ptr< const GizmoVisual > ConstGizmoVisualPtr
Definition: gz/rendering/RenderTypes.hh:321
shared_ptr< RenderWindow > RenderWindowPtr
Shared pointer to RenderWindow.
Definition: gz/rendering/RenderTypes.hh:243
shared_ptr< const GpuRays > ConstGpuRaysPtr
Definition: gz/rendering/RenderTypes.hh:305
shared_ptr< const DepthCamera > ConstDepthCameraPtr
Definition: gz/rendering/RenderTypes.hh:289
shared_ptr< const Object > ConstObjectPtr
Definition: gz/rendering/RenderTypes.hh:357
shared_ptr< PointLight > PointLightPtr
Shared pointer to PointLight.
Definition: gz/rendering/RenderTypes.hh:219
shared_ptr< Heightmap > HeightmapPtr
Shared pointer to Heightmap.
Definition: gz/rendering/RenderTypes.hh:163
shared_ptr< const Sensor > ConstSensorPtr
Definition: gz/rendering/RenderTypes.hh:401
shared_ptr< const ObjectFactory > ConstObjectFactoryPtr
Definition: gz/rendering/RenderTypes.hh:361
shared_ptr< LightVisual > LightVisualPtr
Definition: gz/rendering/RenderTypes.hh:183
shared_ptr< const ParticleEmitter > ConstParticleEmitterPtr
Definition: gz/rendering/RenderTypes.hh:365
Shared pointer to Visual.
Definition: gz/rendering/RenderTypes.hh:269
shared_ptr< RenderPassSystem > RenderPassSystemPtr
Shared pointer to RenderPassSystem.
Definition: gz/rendering/RenderTypes.hh:231
shared_ptr< const Material > ConstMaterialPtr
Definition: gz/rendering/RenderTypes.hh:345
shared_ptr< const SpotLight > ConstSpotLightPtr
Definition: gz/rendering/RenderTypes.hh:408
shared_ptr< const AxisVisual > ConstAxisVisualPtr
Definition: gz/rendering/RenderTypes.hh:281
shared_ptr< Grid > GridPtr
Shared pointer to Grid.
Definition: gz/rendering/RenderTypes.hh:155
shared_ptr< COMVisual > COMVisualPtr
Shared pointer to COMVisual.
Definition: gz/rendering/RenderTypes.hh:179
shared_ptr< const RayQuery > ConstRayQueryPtr
Definition: gz/rendering/RenderTypes.hh:373
shared_ptr< const PointLight > ConstPointLightPtr
Definition: gz/rendering/RenderTypes.hh:369
shared_ptr< Mesh > MeshPtr
Shared pointer to Mesh.
Definition: gz/rendering/RenderTypes.hh:199
shared_ptr< ObjectFactory > ObjectFactoryPtr
Shared pointer to ObjectFactory.
Definition: gz/rendering/RenderTypes.hh:211
shared_ptr< SpotLight > SpotLightPtr
Shared pointer to SpotLight.
Definition: gz/rendering/RenderTypes.hh:257
shared_ptr< Camera > CameraPtr
Shared pointer to Camera.
Definition: gz/rendering/RenderTypes.hh:107
shared_ptr< InertiaVisual > InertiaVisualPtr
Definition: gz/rendering/RenderTypes.hh:171
